lets see....
Apexi AVC-R boost controller
Aspire brake swap
Replacing bearings and seals at all 4 corners
Replacing both drive axles
hidding some wires inside
Replacing main crank shaft seal (FIXEd OIL LEAK1!!@!@##)
all new fluids(transmission, oil, brake fluid)
All in all, my car is finally starting to turn into a real car! not leaking oil, no axles going CLICK CLICK CLICK, being able to stop! I am over welmed. here are some pictures!
Just so happens that the boost sensor for the AVC-R fits perfectly where the boost sensor for the b6t was!
Aspire brake swap
