RPM at MPH
  • RPM at MPH
    I have a 88 4speed without a tach.
    I was wondering if someone could tell me what RPM the motor is turning at 55mph, 65mph and 70mph in 4th gear.
    Thanks
    ~Jeff
    1988 Festiva LX Silver 5speed. 219,000 miles. My new daily driver.
    1988 Festiva L Plus Red 2brl 4speed. 504,477 miles and holding till I get the speed-o fixed.
    2003 Mustang GT 5speed
    I have no idea I don't drive my festiva often enough to give you an accurate answer, but i kknow someone will chime in. Go get a tacho cluster and swap it.
      not sure what the MPH is but at 4000 rpm in 4th i'm doin roughly 120 - 125 KPH, and around 3000 rpm it's around 100 KPH, tomorrow on my way to work i'll find out more for ya
        Ok guy's. If it wouldn't be too much trouble, on your way to work this week could someone please get me these numbers?
        Thanks a bunch.
        ~Jeff
          I will make you a little vid on the way to work this morning
          I was going to do it the other day , sorry .
          HD2500 Duramax Chevy
          Z28 LS1 power 500 +
            Not real sure if this will help Jeff , but here was one at 5:45 am , and one when I got off at 3 PM .
            remember this is a 5 speed .
            This video on top worked after I downloaded it ?? now it will not play, click the pic to the right , if it does not play >>
            Yes you can hear the speedo cable in this one , it was 15 degrees , and it only does it for a mile or so .
            :lol:
            Z28 LS1 power 500 +
              15 degrees and you didn't even let it warm up? jk. 10 minutes of warming up and mine reads like it was just started.
              92l efi 240K+ stock
                Doug, that was awesome :shock:
                I wasn't looking for maxed out numbers though.
                Since mine doesn't have a tach, I was just wondering what the RPMs were at different highway speeds in 4th gear.
                ~Jeff
                  Sorry I could not resist , that is how I drive all the time .
                  Looks like 74 MPH @3,500 RPM's in 4th .
                  Z28 LS1 power 500 +
                    I spin about 3800 at 70mph in my 4 speed
                    Currently Festiva-less. Please don't hate me
                      What tire size you guys running?
                        okay, on my way to work today i left my car fourth to get some numbers for ya, hopefully this is what you're looking for
                        45MPH @ 2400rpm
                        50MPH @ 2700rpm
                        55MPH @ 2900rpm
                        60MPH @ 3200rpm
                        65MPH @ 3500rpm
                        70MPH @ 3750rpm
                        75MPH @ 4000rpm
                        80MPH @ 4300rpm
                        now keep in mind my speedo is in KPH and i was looking at the small numbers for MPH and trying to watch the road and see my tach at the same time so the speed @ rpm's might be a hair off but it should be very close
                        by the way i got my stock 12 inch tires on the car too
                          175 /70/13 on mine
                          Z28 LS1 power 500 +
                            Damkid, THANK YOU! , thats just what I was looking for. 80? - you went above and beyond the call of duty.
                            Packrat, I like the Camaro burnout vids.
                            Being the Chevy guy you are, what about taking the drivetrain out of the new 305hp Impala's and putting in the rear of a Festy?
                            ~Jeff
                              It is a small enough package to fit , but I am not sure what kind of suspension to fab for it , to make it work from a FWD to a RWD set up .
                              How about a AWD set up from a SS Trailblazer 396 hp . OH YEAH
                              Z28 LS1 power 500 +
