were any of the festiva clusters backlit? i thought i had seen pictures of spedos with backlit numbers, not just the lights on the top.
cluster illumination?
the tach/speedo clusters are backlite"FLTG4LIFE" @FINALLEVEL , "PBH"
Stefan,
believe you are correct!
Because I swapped light bars from my 4 bulb white none tach cluster to the orange tach cluster which only had 2 bulbs.
Minor soldering skills needed.
Easy and much better visibility!
Pu241'93 Blue 5spd 230K(down for clutch and overall maintanence)
^^^ I doubt it would fit inside the spot already prepared in the festiva's dash... the speedo should plug up though if you wanted to make a custom cluster from it, and the rest (fuel, temp and tach) are all electrical so a little soldering or other fabrication and you could put the guages in there, but probably not the complete clusterNo festiva for me ATM...
