cluster illumination?
  • cluster illumination?
    were any of the festiva clusters backlit? i thought i had seen pictures of spedos with backlit numbers, not just the lights on the top.
    89SX funtop! Fully loaded!
    RIP 90LX
    the tach/speedo clusters are backlite
      my white face tacho cluster is backlit in green, and the orange ones are in orange, but none of the non-tach ones i have seen have been backlit
      No festiva for me ATM...
        niceee. now i just have to find a white faced kph tach cluster :?
        RIP 90LX
          I just noticed that the other day, I need a tach cluster just for saftey because I cannot read my stock cluster in the dark.
            How many over-head bulbs did the non-tach clusters come with from the factory?
            just wondering, because ive heard of people adding more. One of mine has 4 and the other has 2
            RIP 90LX
              Early orange ones had 4 bulbs while the white ones had 2
                my orange one has 2 and my white one has 4 :?
                RIP 90LX
                  Stefan,
                  believe you are correct!
                  Because I swapped light bars from my 4 bulb white none tach cluster to the orange tach cluster which only had 2 bulbs.
                  Minor soldering skills needed.
                  Easy and much better visibility!
                  Pu241
                    ^^ i did the same thing w/ the same color/type of clusters.
                    92l efi 240K+ stock
                      Has anyone put an MX6 cluster into a Fesitva? I have one..
                        ^^^ I doubt it would fit inside the spot already prepared in the festiva's dash... the speedo should plug up though if you wanted to make a custom cluster from it, and the rest (fuel, temp and tach) are all electrical so a little soldering or other fabrication and you could put the guages in there, but probably not the complete cluster
