rolling chassis weight?
  • rolling chassis weight?
    Does anyone know how much a Festiva without an engine or tranny weighs? Or what's the lighest drivable Festiva someone has weighed?
    1986 Comp Prep SVO Mustang(1 of 83) Four cylinder turbo! (Think first Fox body "R" model!)
    The stock transmission and engine together only weight like 150 lbs, so my best guess is about 1650 lbs
      150.. thats it.. lol
      88' Ford Festiva
      97' Chevy Silverado Z71
      94' Chevy S-10
        well maybe 250, I can pick them up.
          Really?
          So the engine and tranny weight the same as 3 large bags of dog food!
          At 150 lbs you wouldn't need a engine hoist!
          Sounds like another you can "pass emissions but your cat. could still be clogging up" with no explanation as to how!
          Try 300 to 350 lbs for engine/tranny combination.
          The tranny it self is probably 60 -75 lbs maybe more.
          Anyone have a better estimate than that?
          I thought someone weighed the engine at one time!
            The trans is about 65 lbs. I'm guessing the engine at 175 - 210.
              I could be talked into a combined weight of 300 lbs meaning with the 63 hp we get out of the unaltered B3.
              We get a little less than 5 lbs per HP which seems reasonable!
                WOOOooo nellly. Relax man. No need to get all RAWR. People make mistakes. No need to get all rowdy and cut throat.
                88' Ford Festiva
                94' Chevy S-10
                  you can pick up the engine and the trans while they are still bolted together? I will have to have you come over when I pull the engine out of the donor car... I have a gravel driveway and a hoist just won't roll around. But I could have you carry it to where I need it...
                    I had a heck of a time wrestling an engine/tranny down the ramps off my utility trailer by myself. I'm not thinking it's real light... I certainly couldn't pick up the motor!!
                      I said I could pick it up, I didn't say I could walk around with it! There is a big difference there. I could be talked into 300 lbs but no more.
                        I can pick up the engine by itself, barely. Gforcefd, I think your 250 guess is pretty accurate.
                          I believe I remember someone who took apart their Festiva and put it in the back of their truck said they got it down to 850 lbs... That was with everything stripped (windows, all interior pieces, bumpers and supports, hood, fenders, etc...) - I believe they even took the brakes off... But put that stuff back in and you'd probably still be around 1000 lbs all together?
                          Wouldn't be very fun to drive like that thought.
                          Simon - pimptiva.com
                            Engine weighs about 240lbs, manual trans weighs 45 lbs.
                            ~Jeff
                            1988 Festiva LX Silver 5speed. 219,000 miles. My new daily driver.
                            1988 Festiva L Plus Red 2brl 4speed. 504,477 miles and holding till I get the speed-o fixed.
                            2003 Mustang GT 5speed
                              240 and 45 sounds best(ish)
                              the engine can be lifted off the ground or slung into a pickup bed manually, and the trans can definitly be tossed over an average chain link fence
                              But what difference does it make? And do none of us own a scale?
                              the title on my 90 festiva reads 1640 empty, my 92 reads 1789 empty - were there come up with the difference is a mystery
