i was working under my festiva and the one side i jack up the back wheels are off the ground also and does not seem safe. how does the other owners secure the car while working under it?
working under festiva
What 25Horseplay said and preferably in pairs!'93 Blue 5spd 230K(down for clutch and overall maintanence)
^ Bingo!
Makes it much more stable when you have to yank out an axle or wack a tye rod end!'93 Blue 5spd 230K(down for clutch and overall maintanence)
Cinderblocks with 2 by 4s on top to keep from scratching/ denting here. Never, never work under a car that is held up only by a jack. Actually been to a funeral this year for a guy who was doing that. :cry:
1989 L - 247K miles Slick
Can not agree more about never work on car held-up by a jack!!!!!!Originally posted by batstivaCinderblocks with 2 by 4s on top to keep from scratching/ denting here. Never, never work under a car that is held up only by a jack. Actually been to a funeral this year for a guy who was doing that. :cry:
But the 2x4's on top of the block (if you don't have proper jacks) should be to spread the load of the jack point edge (denting is secondary). I have seen the edge cut into a cinder block and once a notch is made (stress concentrator) the block can proceed to crack and crumble!
Now a concrete block is different, a lot heavier too, but more durable from a compressive load stand point!
Anyway just be safe!'93 Blue 5spd 230K(down for clutch and overall maintanence)
^^ I use solid cinder blocks that weigh just about as much as the car. Not as much worried about damaging the blocks as I am about damaging my car. Or myself. :!:
Big logs and solid concrete blocks.....good idea
^^There's something I never thought of...plywood windows :laughing3:
Im going to tint them and no one will know.
Man Fresh...I am not not sure about the front to back movement on that....does not look too sturdy.....unless you have the brakes set...then I guess it can't roll...lol"FLTG4LIFE" @FINALLEVEL , "PBH"
Poverty produces creativity
