Hey guys,
I picked up a blaster coil for my B6 car, and needed some advice on installation. What did you guys do with your coil bracket and the wiring once you installed the blaster? Did you guys just clip the plug off the end of the wiring harness and add a ring connector on each wire and put one on each stud on top of the coil? If you guys have pictures of your coil set up, I would appreciate seeing them.
Thanks
Thanks
