I have a 1988 lx with power steering and ac that wont idle any lower than 3000rpms. Ive checked vaccum lines and it has new cap rotor plugs/wires. It seems like its getting way too much fuel and every adjustment i found on the carb does not make any difference.
carbed festiva idles high all the time
Welcome my son!
Now go to "profile" above and educate us as to your approximate physical location.
Then follow this link:
"Search" is a powerful tool once you have mastered it.'93 Blue 5spd 230K(down for clutch and overall maintanence)
if the wire from the alternator to the electric choke is not hooked up , they will idle very high.i just repaired one that was doing the same thing.1960 willys pickup
1967 jeep cj5
1988 festiva
1989 festiva
1990 festiva for parts
1991 s-10
my 89 did the same after i sprayed some carb cleaner down the throat, rpms stuck while test driving, i guess i loosened some gunk in the back barrel that caused the throttle plate not to shut completely, stopped the car and sprayed some more cleaner down throat and worked the throttle plate up and down with plastic screwdriver to make sure the plate closed and now runs fine,,,u may want to oil your accelerator cable too, may be sticking or have a burr in the cable,, and check the dashpot for free movement ,after reading your post, do u just have high idle with a/c on or is it all the time,,,let us know,,,,previous cars to fix up;
86 300ZX
85 RX7 GSL
88 Corolla FX
89 Festiva LX 2bbl 5 speed
