valve cover TORQUE Values? w/NEW rubber gasket (VS50309R)
  • valve cover TORQUE Values? w/NEW rubber gasket (VS50309R)
    '90 Festiva L- Plus 1.3L FI 5speed
    Son wants us to replace the leaking original valve cover gasket, on his proud "new" car.
    ( I always use Fel-Pro Perma-Dry gaskets and never have further leaks.)
    The gasket box says only "Torque to OEM specifications."
    BUT his ALLDATA online manual does not list a torque value for the valve cover/gasket.
    And the Haynes Manual #36030 is not in stock at local Advance or Autozone stores , and the 1 copy in the library is out and on hold.
    I can hand tighten for now, since its been leaking since he got it anyway.
    But if anyone can help, we certainly appreciate it.
    Any other "new owner" suggestions also?
    ( I have quickly scanned through this site but not in depth (yet). GREAT SITE !)
    I have already stopped the biggest oil flood by replacing the dried out O-ring on the distributor. ( $2 )
    And hopefully the other end ( @ the cam , crank, timing belt ) still has good seals.
    Car runs great and is a ball of fun!
    AC ( R134 convert) even works great!
    THANKS!
    44 to 80 in lbs.
    93 GL modyfied!!!
    :fish:
      enjoy the car and remember us when it comes time to move on and sell the car!
        Originally posted by 25Horseplay
        44 to 80 in lbs.
        =just barely. More of tweak than a torque.
          Yep thats INCH lbs. Not to be confused with Ft lbs.
          93 GL modyfied!!!
          :fish:
            grab a 3/8 drive ratched by the head wrapping your fingers around the deep reach socket and twist them all about the same. Repeat once or twice.
            I dunno worked for me with Felpro's
            it runs so sweet
            91 L 5spd
              THANK YOU ALL !
              Now , if son will show up after work with the car , I can replace the VC gasket and continue finding and fixing the oil leaks!
              I will post the results here.
              Meanwhile, hopefully you can answer another question that I will post in a separate post.
              THANKS !
                The front main seal is another popular leak!
                93 GL modyfied!!!
                :fish:
                  I like to put grease, like high-temp wheel bearing grease, on valve cover and oil pan gaskets to prevent leaking. I also use it for oil filter gaskets and the threads on oil drain plugs. Guaranteed no leaks ever; I never have to replace those little seals on the drain plugs.
