wire identification on my festiva
the round metal ones bolt to the front of the head near the water bypass hose on the front. i took those off while replacing the bypass hose and a long bolt holds it on at least one of them. i think that a spark plug wire holder is bolted to it also.
Monkeyracing is correct. Also the loose black wire grounds with the other black wire on the same terminal.sigpic
