88 LX
125k manual
Replacing the cylinder head and decided to clean everything before putting it back together. Got the valve cover off and noticed the little splash shield thing inside. I removed that and noticed it had a gasket between it and the valve cover. Does this gasket come with a typical head gasket set? What's it called in case I need to buy it separate? Or do I even need it? Thanks.
125k manual
