Need ignition cylinder lock and key
  • Need ignition cylinder lock and key
    The key for my 1991 Fevstiva L is starting to hang up in the locked position. Autozone, Napa, Car Quest, locally do not have one and cannot find one. Rockauto does not have one. Any ideas where I can find one?
    Thanks,
    Art
    I guess youve sprayed some good lube in your current ignitiion ?
      Yes. It is not "sticky" rather the cylinder is worn badly and jams in the "locked" position. Wiggling the key vigorously unlocks it, but I know it is just a matter of time before it is so worn that this will not work either.
      Just need more ideas for a supplier to get the part from. Installing it is no problem
      Art
        Try Festiva Motorsport, they did carry new locks at one time. Or try a want add on the site here for a good used set.
        93 GL modyfied!!!
        :fish:
          turn the steering wheel back and forth and try the key. it has something to do w/ the steering wheel lock
          92l efi 240K+ stock
            ^ X 2, and you might try to get a new key cut from an good original key if you have one. Just an easier/cheaper thought.
              NAPA online
              Ignition Lock Cylinder & Keys
              Item#: MPEKS6664SB
              Price: $14.99
              tax and shipping not included
              it runs so sweet
              91 L 5spd
                I believe I tried that one kzbill. That was the wrong one. I went into a napa, and a guy pulled out a book, and I found one that looked very similar to ours, if not exact. The only problem for me at the time was that is was over $100....i think $120. I had to find one from ebay to get me going again, but if I hadn't I would have certainly tried the $120 one from napa. Zfestiva, get a picture of your ignition lock cylinder before you go to Napa if you are going to go that route just to save you some hassle.
                Come on kzbill...do you think it would be that easy for us festy owners heheheheeh. They have to make everything difficult for us. LOL
                By the way, what part of Wisconsin are you from??
                90 Festiva with Brand new B3, 5spd
                92 B6 Festiva, 5spd
                  Most experience locksmiths can cut a key without a original key, but just off of the cylinder itself.
                    U pick it on n. watkins in Memphis has several.
                    David
                      Sorry, it looked like a ford lock cylinder
                      the link above should, I hope, take you to the page and you can look at it for me. I haven't had to replace mine so I am not sure.
                      yes it is hard to find parts, I agree. But I recently found a Denso fuel pump relay from a major for 29.99 + ship thats a 75$ relay everywhere else.
                      Google map 53050 I am 2 mi. south of town. (Mayville) 45 mi. north by northwest of Milw.
                      it runs so sweet
                      91 L 5spd
                        Doesn't look like the same lock to me. May want to try looking for a Mazda or KIA lock.
                        David
