What is the proper way to tension a timing belt, how much torque do you apply to the bolt on the tensioner?
Timing belt
your best bet would be to pick up a haynes or chilton manual from your local parts store for about $20. They have good writeups on procedure, photos, and torque specs.Jim DeAngelis
Well the manuals don't even help you that much, I just made it tight enough where I felt the belt wouldn't skip (not too tight or it will snap) and tightened the tensioner to about 25-30 ft lbs.. -KyleCosmic Blue 2008 Mazdaspeed 3 - Mostly Stock...
White 1990 Ford Festiva - B6 SOHC powered 50 shot = 14.5 @ 94 mph Gone but not forgotten
Proud member of Chicken Mechanix Racing
