'88 Festiva... 180,000 miles 4speed manual
I had a noise in the transmission. I changed the throw out bearing, pressure plate. and clutch plate, that was not the problem. I drove it a few miles and it started popping out of 4th gear, then it got to the point that it wouldn't go in to 4th at all.
So I figure it is time to change/rebuild the transmission and I see a bunch of change outs with used transmissions and not many rebuilds.
My question is... how hard is it for somebody with good mechanical skills to rebuild a transmission in a Festiva... and what special tools are required?
a little steep but for a five speed that's not to bad.
