How long does it take for a festy to fully warm up. On 95 degree days it takes my carbed festy around 20 minutes to fully warm up and even longer on cold days.
warm up
A new thermostat is a good maintenance item anyway. Replace it and see if it helps.Axlander9289, brother of ThisVelologist
Festivas past:
Aqua '92 Festiva L - Sold "Dale"
White '89 Festiva L Plus - RIP "Dudley"
White '93 Festiva GL - Sold to thisvelologist "Frito"
Red '91 Festiva L - Sold to Louieisawesome "Geraldo"
Current Fleet:
Aqua '93 Festiva L with Aspire brakes "Dale Jr."
Black and White '93 Festiva GL Sport (White alloys and spoiler are long gone) "Blues-tiva"
White '15 Ford Transit Connect
i went to look at a festiva and when he started is it reved up to like 3k is this normal on a carbed one
Mike, AKA the sasquatch
thanks for the info
Plugging in a block heater on cold mornings helps. Even on cool mornings my carb'd Festiva starts easily and idles at a lower rpm after 1/2 hour of preheating.
Yes, the fast idle adjustment screw is the metal one with the spring next to the throttle.Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
[quote="WmWatt"]Plugging in a block heater on cold mornings helps.quote]
If you don't have a block heater, I've used a heat lamp or a 100 watt bulb attached to a trouble light. Just put it in the engine compartment next to or shining on the block. Worked for me at 40 below on a 6 cylinder.Where am I, and what am I doing in this handbasket??
