Bushing needed?
  • Bushing needed?
    I need the bushing that goes between the flywheel and the torque converter. it came out in two pieces. Cant get anyone to tell me where to find one?
    the local Ford garage has no idea whet I am talking about???? they cant find it?
    HELP anyone.....
    Thank you
    Mark
    settlements@joblists.org
    Email me at: parts@myfestiva.net
    Call me at : 731-707-2164
    FMS may be, or try to take to your Ford dealer the sample of the broken bushing. If that fails....... JunkYard it is!!!!!
      AFAIK there shouldn't be an input shaft bearing for the AT festies, that's reserved for the manual tranys only (yeah, just confirmed this with the factory manual.)
        there is a small bushing that goes between the torque inverter and the flywheel, it sits into the indent in the end of the crank, I just had mine out swaping the motor
          to what purpose is that bushing for?? there are no mentionings of it in my factory manuals. does the t/c contact the bushing in any way, or is it possibly used as a locator for instalation? i'd like to know myself.
            I think its just a spacer, it sits in a recess on both the crank and the torque inverter, kinda sandwiched in there, hears a picture of it sitting in its recess in the center of the crank, it knida looks like part of the crank in this pic though
              don't know if you'll be able to make it out on this diagram. in the upper left corner is part#6381. this is described on the ford parts fiche as 'ADAPTER(CRANKSHAFT TO CONVERTER) full ford part# is E9GZ6381A.
                Wow, Thanks for all the info from everyone. I will take the Ford number and try to order one....Thanks again for all the great help guys.
                Mark
                  ford may tell you that it is obsolete but it is still available from other sources. pm me if no luck.
