MSD 6A ignition module and coil
  • MSD 6A ignition module and coil
    Is anyone here using an MSD 6A module in their Festiva? I have one sitting in my garage along with a blaster coil that I might as well install in my festy. Which wires go where? Does the magnetic pickup wire from the module gets used or is the installation done according to the instructions for a points/electronic ignition amplifier install? Any info will be greatly appreciated. Thanks!
    Oscar
    Oscar
    I have it on my 93, I use the existing coil wire for the input to the MSD box, from the car Black/White wire go to the MSD box Red, Yellow/Green wire go to White wire. I got it mount at the Firewall over the passage side. Good Luck -Sam
    The line up -
    2016 Focus RS
    2005 Mini Cooper S
    1995 Turbo Mustang
    1986 Buick Grand National
    1991 Escort GT (Daily)
    1980 Fiesta
      Thanks, that's exactly what I was looking for. I was not sure which diagram worked with the festy but your reply clarified that. Here's the diagram if anyone else is interested.
      Oscar
        Sam! Glad to see you!
        93 GL modyfied!!!
        :fish:
          OK, now........ Happy Thanksgiver!!!!! to all and don't just stuff the turkey, mine's in the oven!
          it runs so sweet
          91 L 5spd
            did you notice a difference when you put it in
              the turkey?
              it runs so sweet
              91 L 5spd
                one of mine has a msd,sat up now no spark,no pulse fromstator
                96 Ford F-150 XLT
                93 Festiva L (Modified)
                92 Festiva L
                68 Mustang GT 428cj
