Today I connected the (kickdown solenoid?) between the lower carb and the firewall and hooked up that linkage to the throttle with the help of my friend Marie, who pushed down on the gas pedal for me while I fiddled.
I hooked up another vacuum hose or two. Some I identified as extraneous since their counterparts were already attached to my ebay carb.
After a few squirts of starting fluid, nothing was improving. After I did a few more things, she ran for about a minute! That wasn't starting fluid!
I started her a second time successfully and backed her out of my garage and then back halfway inside before I turned her off. She's still heating up excessively around the exhaust manifold and the warming pipe that comes off of it. I think it was Jim DeAngelis who thought this was an indication of "running too lean."
This is the same problem as I had before. The shop I took her to said she needed a good carb cleaning and/or rebuild. That's why I was working on the "replace carb" end of it.
Any thoughts? I'm not sure what to do other than to hire a mechanic to come out and look at her.
Tomorrow I'll also use the EVTM manual to try and decipher the vacuum lines and stuff. I'm running low on energy now.
I feel good though! She's alive!
Karl
Karl
