2500 Rattles... help?
  • 2500 Rattles... help?
    really annoying noise right at 2500 rpm. no other. it comes from the right side of the engine bay (passenger) and it's really annoying. loud little bugger.. kinda like a screw is loose and rattling really fast or like my cone filter is rattling against the side or something...
    it's a metal on metal rattling noise.
    ideas?
    doesn't do it if the car is sitting still... i tried that last night... idk why.
    Redlands, CA
    1995 Ford Aspire [Red]
    Try having somone in your car with you listening for it at the 2500rpm limit.
      Have you checked all of your heat shields from the manifold all the way to the cat .
      HD2500 Duramax Chevy
      Z28 LS1 power 500 +
        after you got gasmaybe?
        96 Ford F-150 XLT
        93 Festiva L (Modified)
        92 Festiva L
        68 Mustang GT 428cj
          Just a guess....Right side...check the motor mount....a round wheel above the belts....near the strut tower.
          Joe Lutz
          The SKATE ..... 1992L 5spd
            wes i have an asp. will this make the exhaust diff from festy's where you couldn't tell me this...? .... where are all the heat shields located approximately? i know of the one in front over the headers... i just don't know off the top of my head where the others are. help?
            phan... happens at all times for some reason... tried that too lol
            glutz.... i'll check... why would that rattle though? i've got my cone filter right above it but i've suspended it with quick ties lol it doesn't seem close enough.. will check though.
            thanks everyone. will update when i can.
            Redlands, CA
              I like Wes' Idea. there are heat sheilds above the exahust under the car too. make rattle happen and listen.
              it runs so sweet
              91 L 5spd
                ????????????????? Wes
                The heat shields are wrapped all the way around the down pipe from the manifold all the way to the cat converter .
                They deteriorate and become loose and like to rattle at different RPM's
                The top cover over the manifold will make a lot of noise also , more when they start cracking around the bolt holes .
                Z28 LS1 power 500 +
                  the Idea of having someone else run the throttle?
                  it runs so sweet
                  91 L 5spd
                    I've had heat shields do that on more than one festiva.
                      my bad packrat... i wrote something to him i thought and then it deleted... my computer's quite odd lol
                      but yeah.. i'll check that today. doesn't do it when the car isn't moving so i can't exactly have anyone else run it while i look... doesn't work too well... but yeah.
                      Redlands, CA
                        FOUND IT! WOO!
                        it's the heat shield under the passenger seat. gotta figure out how to fix it now. can i remove it? or how can i fasten it on better??? help?
                        Redlands, CA
                          Years ago....maybe 15 or so.... mine made noise. I went to take it out, the nuts and bolts holding together broke, I put new ones (stainless) in with washers top and bottom. Not a problem sinsce.
                          Do you need it...without looking... i think the shifting linkage is right above it, without it, it will rust up quicker, making shifting difficult.
                          Joe Lutz
                            Before mine got real bad , I took a stainless hose clamp and fit it around the pipe/heat shield and crank it down , the noise left .
                            Now I have no heat shield at all , I took them all off and the one on top of the mani.
                            No problems
                            Z28 LS1 power 500 +
                              agreed. I've had no heat shields for years, with no adverse effects.
                              Jim DeAngelis
