I have a 93 Festiva L, close to 600,000 miles, 2 door, with a manual trans.
Some months ago, I had to replace the clutch pedal itself, since the part that the cable attaches to had bent all out of whack! ( Only I can ruin a dang pedal!)
Now, the small bracket that the cable feeds through on its way to the pedal, that is attached to the much larger bracket that holds both the brake and clutch pedals, has bent and broken one if its welds, meaning the clutch will not engage.
I believe that I am going to try removing the large bracket that holds the pedals, break the small bracket off, grind down the broken welds, drill 4 small holes through both brackets, and re-attach with bolts/nuts.
Has anyone else run into this? How did you fix it? Is the pedal bracket as easy to remove as it appears? Suggestions?
