I have 1990 festiva l automatic and want to know where windshield washer pump is located. thnaks ahead
is locate at the bottom of the windshield washer fluid tank. you can access to it but you probably need to get the front driver wheel and the inter fender cover off.The line up -
2016 Focus RS
2005 Mini Cooper S
1995 Turbo Mustang
1986 Buick Grand National
1991 Escort GT (Daily)
1980 Fiesta
Hey, You are right - Somebody needs ot do a "How to Install an aftermarket pump" for this car. THe problem is I think the pump is in the bottom of the tank and dirt gets in there and prevent it from pumping.
Even if you put a remote pump in, it may be too clogged to pass fluid. I keep a "spritzer" bottle of window cleaner in my car. I reach my arm out the window and spritz the windsheild. That was my windsheild washer repair -LOL!
my pump died, i took the pump out, took it apart and fixed the motor, put it back together and caulked the bottom up, put some fluid in the tank and it started leaking... i figured screw it, its an extra 10lbs anyway, pulled the whole thing out, filler neck, tank, motor... deff an extra luxury item i do NOT need!~Nate
Current cars:
FOTY 2008 winner!
A couple of years ago I bought a replacement pump from autozone.Renegade-Midwest Festiva Inc.Illinois Chapter
99 Dodge Caravan SE
95 Taurus SHO auto 265hp
94 F150 351W auto (for sale)
95 Honda 1500 Goldwing SE
95 Iszuzu Trooper LS
Wher do you put an after market pump?? Some whe between the fluid and the wipers! Pump failure....probalbly 99% of them...come from not being used...or a dry container...or running a pump dry.Joe Lutz
The SKATE ..... 1992L 5spd
My pump still works, but the tube is clogged JUST before the sprayer, and easy fix, but, being a mechanic, my own car is the LAST one I work on, thus I have done without for many years!Contact me for information about Festiva Madness!
I'm thinking of putting in a junkyard pump and bottle from another car on my firewall, right side. I'd wrap the extra long hose around my heater hose, cover that with insulation, and when the engine warms up: HEATED WIPER FLUID!
What do ya'll think?
That is a cool idea Karl !!
Yes wrap the hose around heater hose , or if you could find a way to heat the tank itself .
I think Santa knows I want a remote start for my Festiva :lol:------------------------------------------------
HD2500 Duramax Chevy
Z28 LS1 power 500 +
thats a sick idea, i love it!Originally posted by Safety GuyI'm thinking of putting in a junkyard pump and bottle from another car on my firewall, right side. I'd wrap the extra long hose around my heater hose, cover that with insulation, and when the engine warms up: HEATED WIPER FLUID!
Karl
i dont know if anyone carries them where you are, but up here you can atchuley buy something like that at canadian tire.89SX funtop! Fully loaded!
RIP 90LX
There are high-end aftermarket electric heated washer fluid kits, but they are expensive. This would involve looking for an appropriately sized and shaped bottle to mount on the firewall, lots of fluid hose able to handle high temps, some rewiring, and insulation.
Shouldn't cost more than $20 to $30 or so.
The downside is that you have to wait to have your hot fluid.
Another way to do it would be to use a DC heating element, probably right before the fluid goes to the sprayer.
i know, i like the home-job way anyways
I was thinking... with doing it the way you are talking about... you would first get cold fluid (the liquid in the line after the heated winded section) then you would get some hot fluid from what was up against the heater hose.. then you would get cold fluid again... what if you were to insulate the bottle.. and have it constantly circulating thru the hose that wraps around the heater hose... with a pump that could run for long durations of course..
this is the one canadian tire sells $60cdn
RIP 90LX
my dads mercedes has the coolent plumed right through the windshild washer fluid, go to the junk yard and take one out and make your own pluming. that is what i would do
Mike, AKA the sasquatch
Here's what I did on Uncle Fester. I took 3/16 steel brake line, made a double-pass loop the width of the exhaust manifold, and sandwiched it between the manifold and the heat shield. Cut the vinyl hose and connected each end to an end of the steel loop. I get hot washer fluid in less than a minute after startup.Jim DeAngelis
