i put all new gaskets on, was very careful on the install so i am kinda dumbfounded on what it can be, about tired of takin the head on and off.
SMOKIN LIKE CRAZY
You didn't spill some coolant down in the exhaust pipe did you ..just a thought , I have done it , and it takes a while for it to burn out .------------------------------------------------
HD2500 Duramax Chevy
Z28 LS1 power 500 +
Originally posted by FB71ok, WD as a protectant after a bath, that makes sense.
did you plateau hone after finish honing?
FB71 knows his S, great question, keep them comming!!!!!Joe Lutz
The SKATE ..... 1992L 5spd
One valve would necessarily be a bad new valve....why did you change the valve...makes me thing that if the valve was bad the guide might also be shot...though does not explain bad idle.
Smoke color is best diagnosed immediately after a cold start followed by some hi throttle...after the engine sits a while...any leaking system will ahve a chance to accumulate.
If its water or oil burning....you should see a decrease in the respective level.
Anyone...does the 88 use coolant as a pre-heater at the throttle like later models?
Rotate the distributor to see if that improves idle...if the idle improves...the timing belt is not correct. Make shure to marke the dist position before moving.Joe Lutz
yeah, there's a coolent passage right below the carb flange on the intake that gets recirculated untill the t-stat opens. for easier cold starts and low temp driveability.Trees aren't kind to me...
One more question, did you use the proper bolt tightening sequence when you put the head back on it?Contact me for information about Festiva Madness!
