E-brake cable repair
  • E-brake cable repair
    I did an Aspire break swap off of a 97 2 door Aspire onto my Festiva and I did not get an e-brake with the Aspire swap or with the Festiva when I originally bought it. I recently got a Festiva e-brake and its in known good working condition however when the person removed it he failed to unscrew the rubber hangers that hold part of the e-brake mechanism to the i-beam and instead cut them leaving half of the rubber hanger attached to the i-beam and leaving the e-brake without the full rubber hanger on each side. My question now is can I just drill new holes in the rubber that is still intact on the e-brake mechanism or was the rubber length specific? Also I heard that people had problems using festiva e-brake cables after they swapped to an aspire break upgrade. Is there any truth behind this and if so am I still gonna be effected even though I got my i-beam and such off of a 2 door aspire? If there is going to be a problem what is the common fix and what all needs to be changed in order for it to work? Below I have 3 pictures I took to show the rubber hangers on the e-brake mechanism and how much is left on each side (about same length left on each hanger). Thanks in advance guys.
    come on guys, somebody must have my answers.
      Try drilling holes and splicing them together - sounds like a plan to me :-)
      I don't think the length is critical - it just needs to be able to float so that an equal pull is applied to both wheels.
        the cable should work (although i used the aspires), and the length of the rubber should be OK, but your e-brake might work better on one side than the other if the center piece can't move far enough.
        also, your pics aren't loading for me, but that might be b/c i'm @ school.
        ~Nate
        Current cars:
        FOTY 2008 winner!
          Not to whore your post but if that cable happens to not work out with your swap I'd buy it. Good luck getting it to work just the same!
            The rubber hanger lengths shouldn't be critical. Add and splice what you must to mount them securely on the beam.
            As for the e-brake hookup, fab a connector from a cut off Festiva brake cable. I posted some directions somewhere on here lately. I think I said to use an Aspire cable end, but I think it's a Festiva cable end you need to cut off. I'm not sure now!
