Wow...something wasnt right with the re-install...mostlikely in the bearing area....A lost or damged seal...not enough grease...dirty grease...to much torque...not enough torque... spindle nut not crimped....anyway...all need to replaced: Seals/Inner Bearings/Outer Bearings/ Spindle Nuts; The washer can most likely be salvaged.
Most likely all of the internal brake components can be cleaned and salvaged.
You need to make sure that the e-brake was not over adjusted thus causing the wheel to over heat and causing the lube to fail...you will be able t determine this by looking at the inside of the drum and the conditions of the pads.
Start by looking for a dust cap.....not easily found thru retail outlets
