my oil pan has a standard threaded drain plug as well as another hole that is plugged with a rubber stopper, mine wore out and ripped in half draining my oil onto the safeway parking lot. I assumed the rubber stopper was a hack job fix to a cross threaded drain plug but when I went to the junk yard for a new pan I found that they all had this same plug and were all worn and leaking. the part drawing at the ford and mazda dealerships do not show this hole or this part. I am currently using some random vacuum line part, it works but is leaking.
does anyone know what this hole is for, where I can find the correct plug
or if an oil pan from another engine will fit. I would like to get a used pan
because new they are close to $100
