looking for an ac compressor....
  • looking for an ac compressor....
    I have a 93 1.3 festiva, need a new or refurb ac compressor. I cant seem to find one with the correct pulley. anyone know where to find one or ant advice?
    You might try posting a request in the buy-and-sell forum on this site.
    Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006.
      If your Festiva has Factor Air, the compressor should look like this with a single groove pulley.. http://www.techchoiceparts.com/inven...-ac-compressor
      However, you can remove the 4 groove pulley from and replace it with a single groove pulley (and vise versa).
      Nellie - Yellow 90 5spd LPlus (bought '05 at 44,000 105,811 as of 01/18.)
      Trixie - Dark Charcoal 89 L Auto. Bought 06/15/13 $1800 with 89,000 miles / 95,306 as of 01/18. Power windows and swoopie power
      mirrors. Rio front, Aspire rear, 165/55 R14 Miatas. Mercury Tracer front seats. Gave Trixie to my grandson 09/22/2018.
      Rosie - Red 92 GL 5 Speed Sold to Safety Guy 07/12/2018.
      Bessie - Surf Blue '90 5spd LPlus (bought new) As of 10/2018 354K. No longer in the family.. sold to a forum member 10/20/2018
      During the last 15 years I have also owned and then sold or gave away four other Festivas.
        Thanks for the like!!
          Link
            In case this helps I have had to swap pulleys on some VW compressors the puller was easy to make a piece of plate about 4x4 inches drilled 1 center hole and welded a nut to it drilled three holes to run screws into the clutch/pulley put it nut side in and cranked in a bolt. If you don't have a vacuum pump you can build one with compressor from a junk refridgerator.Heck I haven't looked at them real hard but I would think that plenty of mazda and ford compressors would be a swap. I'll see what I can find out.
              Thank you for your knowledge. I have been wrenching since I was 8 and I'm a heavy equipment mechanic. Still don't know everything!! Lol Fortunately I've got an arsenal of tools and metal I can stick weld or mig. About to make an adapter for the air vane for a k&n cone and bend some pipe! I'll have to upload pics
                The ac compressor of my 02 festiva is ok but I know Hex Auto Parts has high performance ac compressor for sale.
                In July last year,I bought an a/c compressor with ac clutch for my father's 2009 Ford Fusion 3.0L.
                He said it's pre-oiled and he didn't need to add oil.
                It can produce cold air in hot summer days after installed.
                He is happy,I am happy too.
                I am very satisfied with this shopping experience.
                  For my 1989 manual with factory AC, I bought a remanufactured Nippondenso 10P13A compressor for $195. This is the one with a single groove pulley, like the techchoice one 1990new links to. I also spent $11 for an AC drive belt from Advance Auto: Carquest 17360 36.
                  It worked great all last summer and I have high hopes for this summer.
                  I think some years of Festivas came with either single or multiple groove, so check yours. I didn't and bought a multiple-groove one first by mistake. It was even cheaper at $88 so hopefully that's what you need. It's part number 77581. Or you could do as 1990new suggests and try to put your old single groove pulley onto it; I didn't think of that.
                  '89 L manual 4sp with 267 on the clock ... much work needed but it goes!
                    it's very easy to swap out the pulleys, so don't be afraid, it's not a hard job at all. good luck. if you need help give us a hollar.
