Sloppy shifter
  • Sloppy shifter
    Hey guys as titile say i have a sloppy shifter ive googled and looked at many part stores they cant find nothing. So any bushing part numbers or anything that can work for it for the shift rod at the trans and at the shifter and does the oem shifter repair kit that most auto stores have work too its pretty worn from use and lets face it nobody likes a sloppy shifter thanks any help would be appreciated .
    Check out this thread for what seems to be the best fix we have found for that issue
      I had to replace the bushings in my ‘88 several years ago, and found a lot of info from the Mazda Protege ppl (ours are pretty much identical)
      Mazda part numbers:
      B001-46-062 - Bushings at the Transaxle, you'll need 2
      GA2a-46-062 - Bushings at the Shifter, also 2
      Fancy bushings:
      Protege Bronze Oil Shifter Bushings -Machined to much closer tolerances than the original ones, these shifter bushings will eliminate sluggishness
      A how-to that’s pretty darn close:
      Ok, so i needed to replace my shifter bushings as all of us have at some point. So i got the parts and went at it. I went ahead and replaced the bug rubber one as well since I was in the area but as previously stated it is unnecessary in most cases. The ojob took about two hours, but that...
      1990 Festiva - Throttle Body/Manual Transmission
      Bought in 2003 with 65k, now 219k
      1988 Festiva - Carb/Manual Transmission
      Bought in 2015 with 150k
        The search function is your friend. Many write ups on shifter rebuilds. Just removed most of my slop by replacing the four bushings and the bushing at the trans. Got the four bushings from NAPA.
