Hey guys as titile say i have a sloppy shifter ive googled and looked at many part stores they cant find nothing. So any bushing part numbers or anything that can work for it for the shift rod at the trans and at the shifter and does the oem shifter repair kit that most auto stores have work too its pretty worn from use and lets face it nobody likes a sloppy shifter thanks any help would be appreciated .
Sloppy shifter
Check out this thread for what seems to be the best fix we have found for that issue
I had to replace the bushings in my ‘88 several years ago, and found a lot of info from the Mazda Protege ppl (ours are pretty much identical)
Mazda part numbers:
B001-46-062 - Bushings at the Transaxle, you'll need 2
GA2a-46-062 - Bushings at the Shifter, also 2
Fancy bushings:
Protege Bronze Oil Shifter Bushings -Machined to much closer tolerances than the original ones, these shifter bushings will eliminate sluggishness
A how-to that’s pretty darn close:
1990 Festiva - Throttle Body/Manual Transmission
Bought in 2003 with 65k, now 219k
1988 Festiva - Carb/Manual Transmission
Bought in 2015 with 150k
