This festiva was an awesome running vehicle until I shut it off one day and then it just refused to restart. A spark tester revealed no spark. Checked coil and have power coming in. Coil itself checks out good though I did throw a spare in that also made no difference to it. I checked the cap and rotor which are fine (almost new). checked the wire from coil to distributor which was fine. Next I checked the ignition module and replaced it with a new one just to make sure. I checked for the pulse on the idm with the coil disconnected and it pulses fine. I am absolutely puzzled by not having spark when everything checks out fine.
I then noticed that I could not hear the fuel pump run at all either so started checking that circuit. I can get the pump to run if I jump the test connector. I'm not sure how one goes about testing the fuel pump relay? I can hear it click when I jump the pump test connector. I have checked the inertia switch which appears to be fine. I am told that there is a fuse some-wheres in the circuit but am unable to find one.
I guess that my real question is... is there any one thing that will cause the fuel pump not to run and have no spark at the same time?
