After enjoying my little car for a couple weeks (changed coolant temp sensor) and it ran so well, I noticed the temperature indicator was starting to show warmer and warmer over about a week. As it turns out, the head gasket was failing. It finally overheated and I used my tow bar to tow it home.
I've removed the cylinder head and found a bad head gasket. I see no apparent cracks or other indications of a bad aluminum head or block.
I was going to send pics, but apparently this site won't accept any picture files over 2 MB. Very sad. I would have liked to share pictures of the bad head gasket, but I'm not going to waste my time editing photos just to accommodate upload file size limitations.
I'm going to try to get the head surfaced just to be on the safe side, but if I cannot afford it, I'll just have to put it back together with the new gasket and hope for the best.
So can anyone give me the recommended torque specs for torquing the cylinder head bolts? Obviously, I don't have a manual.
I know they are not "Torque to yield" bolts because the head gasket set does not come with new ones.
Thanks, appreciate any other help or suggestions besides the torque specs.
Trace
Trace
