I have a 91 Festiva that has a sloppy shift pattern and a clanking noise coming from the shift bar where it hooks to the tranny. I crawled under there and noticed a lot of slop at the tranny side and the shifter side, and it clanks from the metal on metal contact when I jiggle the bar. Does this thing have bushings that used to be there? If so, where can I find them? Any help is appreciated. Feel free to send me an email, or just message me here if you'd like. /// joshua_okla@yahoo.com /// Thank you guys! - Josh
Shifter Linkage Loose and Clanky
Search box is in top right hand corner of screen.. Loose shifitng is a familiar topic here with many fine solutions posted.Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
Okay found the search function. Was at top left, under the menu on my phone. I assume you were speaking of a computer. Anyways, fixed the clanking problem by removing old bolts on the shift bar, and replacing with new ones amd washers to make it tight. Next challenge is, when it's in gear, it wobbles left and right real far.
- Likes 1
Shifter bushings and the shift rod bushings can be bought from the festiva store. www.thefestivastore.comThe Festiva Store
Welcome to the forum....The most helpful car forum on the planet. We know the search function is not the most user friendly, but with patience you will find everything you ever wanted to know about Fetivas and Aspires and some other Mazda based autos.
You need one of these Shift Stabilizer Bar Bushing
$5.00
and four of these to fix your problem.
Shifter bushing
$1.50
Regular This bushing is for the shift rod and stabilizer bar on a Festiva and also the Aspire. There are a total of 4 on the vehicle: 2 at the transmission on the shift rod, and 2 at the shifter.
There is also a solution that requires drilling the linkages out a little and installing shoulder bolts.
If you end up doing the bushings like state above, there is also a big rubber bushing on the anchor point up towards the transmission that usually dries out and falls apart."The White Turd" 1993 Festiva 144k miles. (Winner of FOTM November 2016)
