I picked up three Festivas in the fall, two 90s and a 89 carby. Been tinkering with one of the 90s and man do I have a long list of issues. Maybe the powers that be can offer guidance. I have replaced the fuseable links with fuses, drained the fuel tank and fuel lines.
No spark fuel pump not engaging: It has a new fuel pump and coil, unsure of testing VAF or what all that would effect, have ICM on the way. Fuel pump relay looks to be be new, timing belt is still there. First time I attempted to start it with ether it ran for a maybe a few seconds and stopped and hasn't fired since, motor sounded good in that time tho.
No running lights on passenger side: front bulb was blown replaced it and now the rear doesn't work either. Is this just strange timing or some other issue?
Vibrating sound near but under driver side headlight: This happens only when the headlights are turned on, it changes tone when brights are on. Almost sounded like the washer pump freaking out but I don't think that's it.
No headlights high or low: Have put good bulbs in and I get nothing besides the noise mentioned above
No radio: won't even light up or flicker, not real important now but figured I'd add it in case in can be linked to something else.
Wipers barely move: and I mean they take a minute to cover an inch, I assume the motor is shot
Theres other stuff I'll mention once I can get it running but sitting really hurt this car. I'd like to use it as a commuter vehicle if I can ever track down all these gremlins it's has. Any advice is welcome
