what is the part with the orange plug called it's on the firewall car won't idle top line broke
Part name?
Try plugging the hose with a golf tee or bolt (don't damage the hose). Try plugging the hole where it used to connect to the solenoid.The solenoids are part of the feedback emissions system designed to help the engine burn every last hydrocarbon molecule so they don't come out the exhaust pipe and pollute the air you breathe. Those three are called the idle up solenoids A/C and E/L. The Haynes manual doesn't go into them and just refers the owner to a dealer service department. Disconnecting the hose might be letting extra air into the combusiton chamber or something. If it is not working the check engine light should probably come on. There are a couple of trouble codes (34, 35) listed for the solenoids.Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
- Likes 1
I have an extra if you need it, can ship.'88 L- B6d-Sidedraft Dellorto Carbs-G-Series-Advanced Suspension
- Likes 1
You could remove yours and look for a number stamped on it. Then search the Internet for that number and Festiva part. It would be one of those solenoids, A/C or E/L whatever those letters mean.
Last edited by WmWatt; 07-18-2020, 06:03 AM.Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
- Likes 1
My carburetted '89 has one of those but it doesn't have an air conditioner. I imagine "idle up" means it increases engine rpm's when the air condtioner comes on but on mine that never happens.Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
Mine still works and is more accurate connected to the Escort carb. Better design. AC still works too. If anyone has AC and wants to get an Escort carb make sure it has the idle up dashpot on it. Some of them on Ebay don't. I may have another one of those in the garage. PM me if you want it. I will look for it.
