88 LX 5 spd
130000
I'm not sure what the silver thing is called connected to the air filter housing, but there are four small hoses (one to the left of the 2 large hoses, 3 to the right coming from underneath) and I'm not sure I have them installed correctly.
On the left side of the two big hoses is the blue-spot hose connecting to the filter assembly. On the right side, moving away from the two large hoses, I'm showing the one coming up from the bottom with the in-line filter/valve deal (the one with the arrow pointing down). Next is the white-spot hose coming from the A/C-E/L solenoid valve. Finally is the blank hose from the valve on the passenger side of the A/C-E/L. Can someone verify this with theirs please, if my description didn't confuse you too much. Thanks.
130000
