help
  • help
    i just rebuilt my motor on my 93 egt i just redid the rings and i lubed everything and then torqued my rod bolts down to 35 ft/lbs and tried to rotate it and with all my weight on it i can just barely turn it. is it suppose to be that way? btw i just honed it so im thinking that is why its that hard. also dose anyone know if 35ft/lbs on the connecting rod bolts, it was impossable to find in the manual and im not shure if that is even the right thing i was looking at
    Mike, AKA the sasquatch
    Stop.......I would double check the clearances, it shouldn't be that hard to turn. something is binding.
    What is your definition os "rebuilt".
    Pistons?
    Did you go over sized?
    Crank polish or grind?
    How did you hone the cylinders?
    What piston clearance do you have?
    Did you plasti-guage the rod and main journals?
    Is the head on?
    lots of questions, yes?
    I did a search of the site and came up with this:
    Server MUSANGWIN dirancang stabil ekstrem, pastikan setiap putaran slot berpeluang besar raih jackpot nyata terpercaya.
    it runs so sweet
    91 L 5spd
      KZ...great set of question and....Did you take the crank out?
      Whenever the crank or c'rods are pulled...the bearing caps must go back exactly as they are taken out...they can not be interchanged.
      The connecting rod has and orientation based on the oil hole (someone please help, and can someone look up the torque spec.)
      Pistons should always go back in their respective cylinder.
      The first or second turn...never any more could be difficult...but not like your describing.
      Also...it isn't untypical for wrist pins to get really tight after sitting aroung fo a cuple of days...I've seen a lot of rebuilds where the piston sit in a bucket of oil until they are cleaned/reinstalled.
      Joe Lutz
      The SKATE ..... 1992L 5spd
        connecting rod torque step 1 11-13 lb-ft step 2 22-25 lb-ft
        main bearings 40-43 lb-ft
        Torque specs out of an 89 festiva service manual
        96 Ford F-150 XLT
        93 Festiva L (Modified)
        92 Festiva L
        68 Mustang GT 428cj
          got it all sorted out... it turns out you can only put the conecting rod bottom caps (forgot what they are called) on one way so the where binding on the crank :x but i got it all going smooth as butter
          a nice little tid bit of info for someone rebuilding a bp. put the little tabs/cutouts on the conecting rod and cap on the same side
            Awesome quick lil link KZ
              The link was from this site someplace
              it runs so sweet
              91 L 5spd
