Originally posted by dkdeford
in the correct direction if it is re-installed the injectors will get a burst of gas tank filth. also when looking at the fuel pump be sure to check the seal the pump out tube
goes into. you may have 2 the one the tip of the pump gets pushed into from the bracket gets hard and stops sealing so some people will use a O-ring to seal the out tube.
The O-ring scenario will last for a few week/months or just take a guess. I use Buna hose the full length of the pump out nipple.
