I am trying to replace my passenger side knuckle on my 88 festiva. I have everything off but the nut and bolt for the lower control arm. Can't tell, due to all the rust if it was rounded before, it still looks okay but a 14mm, which is what I think it is originally supposed to be, is too big for both sides and a 13 mm is too small.??? I tried american sockets but couldn't get one to fit. Any suggestions. This is the only thing holding me up. Thanks, Jim
Lower Control Arm...Nut and bolt issues.....
Cleaning with a wire brush and penetrating oil should help. If the socket slips then locking pliers (vice grips) and a hammer might get one of the nuts turning. Sometimes you can tap an undersize socket on enough with a hammer to loosen a nut. Good luck.Last edited by WmWatt; 10-24-2023, 06:36 AM.Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
I have one good left steering knuckle left (free to a good home).. in case you have any problems with your left one. Left Steering Knuckle Front.jpg Left Steering Knuckle Back.jpg
Originally posted by 1990new View PostI have one good left steering knuckle left (free to a good home).. in case you have any problems with your left one. Left Steering Knuckle Front.jpg Left Steering Knuckle Back.jpg
