88 festiva engine light.....
  • 88 festiva engine light.....
    I know to read the engine light codes on my 93 festiva I had to ground the black pin .BUT I don't have that pin on my 88 carb.festiva. Just the clear/white pin and the 6 pin are there, no black pin to plug into and ground????? How do I read and diagnose the engine light on my 88 festiva?? Thanks, Jim
    My East coast Festy, a 1993 (obviously FI'd) is acting like it has a wacko carb here in Pittsburgh. The RPM spontaneously jumps about 500rpm (no tach to measure) for a few minutes, then spontaneously returns to normal. Periodically, the orange engine check light illuminates for about 3 seconds while in motion. I don't feel
    Look at #10 in above thread. This site is a great archive. The search box is your friend, faster than waiting for someone to post a reply.
    Hope that helps fix the problem.
    PS Came up in search on "codes"
      Thanks WmWatt, so i guess I'll try and ground the white pin and see what happens. I thought that was the Tac pin.
        "Ground the STI terminal and watch the light on the dash as is flashes the stored trouble codes." - Haynes manual page 6-6. I just went out to the car and brought in the Haynes manual to check for you. The manual lives in the car in the garage. The search box on this site is indeed faster but I thought I would check to releive any doubt. The STI terimnal is the one-pin near the power brake booster. There is a photo in the manual on page 6-5. Have fun with the flashing light. Who says Festivas are dull?
          Okay, I am getting 7 long flashes but there is not a code for that???? lol figures.
            I thought carbed Festies pre-dated ODB. I've read that ODBII didn't even become mandatory until 1996.
            I have a 1991 that started giving me random check-engine lights this past winter after I let Midas do an oil change when we had sustained sub-0F high temps back in January.
            88L black, dailydriver
            88LX silver a/c, dailydriver
            4 88/89 disassembled
            91L green
            91GL aqua pwrsteer
            92GL red a/c reardmg
            1952 Cessna170B floatplane
