I took it loose from the tranny and used graphite , and lubed it from the tranny end , now it squeaks worse than ever ?
It only use to squall when it was very cold , noise went away in several miles .. Today it never stopped after the bunk lube job
My question is ..will the cable pull all the way out the tranny end to lube the entire cable , without removing the cluster .
