I'm currently replacing my passenger side CV axle, both control arms and tie rods. The problem is the bolt (as can be seen on the pics), that was originally cut off during a previous control arm replacement by the PO, but now the nut on the new bolt has rotten off again and is impossible to take off, hence now I need to cut this bolt off too...
I found the remainder of the original bolt inside of the frame (2nd pic).
Does anyone has any part number or something for it? Where can I get this bolt or something good as a replacement? And no, JY isn't really an option right now, winter's no good for that...
