So ive slowly been loosing brake fluid. I have to top it off every few weeks. This morning i had zero brake pedal, it went to the floor. The rear half of the master cylinder was empty.... but i cant find any leaks? :?:
Mystery Brake Fluid loss
Hi Stef. You and I both know, if the fluid is gone, it went somewhere. I doubt it went into the booster but it could have. Have you checked the wheel cylinders? As far as no pedal, I had that problem on my E-150 and finally realized that the Master Cylinder had an 'adjustable post' that would screw out to increase pedal, and screw in to reduce it. You probably know all of this, but sometimes it helps to restate the obvious.1990 L-Plus, 5-spd, Flamed Festiva.
http://i163.photobucket.com/albums/t...STIVA_0011.jpg
Dude.....has nothing to do with the loss of fluid...think about it..he's loosing fluid and your working on the brake pedal side of the system.Originally posted by clevHi Stef. You and I both know, if the fluid is gone, it went somewhere. I doubt it went into the booster but it could have. Have you checked the wheel cylinders? As far as no pedal, I had that problem on my E-150 and finally realized that the Master Cylinder had an 'adjustable post' that would screw out to increase pedal, and screw in to reduce it. You probably know all of this, but sometimes it helps to restate the obvious.
Stefan...thanks for the radio...you're going to have to pull all the wheels and check all the cylinders and check inside the the master also as mention^^
Don't forget as the pads wear...the level goes down...any soft pads on the car....also....every few weeks...that stinks...thats less than a drop per day.
Do ou have the ford manuals? they have a pretty good sympton/diagnostic sections for what your describing.....Jim D....where are you!?!?!?!?!?!?!?!?!?!............................ ..........................Joe Lutz
The SKATE ..... 1992L 5spd
I agree with checking the rear of the master it is what was out of fluid and it is by the booster and if it isn't at the wheels the only other place to escape is the back of the master.
and yes fluid does go down with brake wear, but you usually don't lose your brakes if he has been topping it off.
Internal master cyl leaks will make the pedal go to the floor.it runs so sweet
91 L 5spd
Thank you...perfect additionOriginally posted by kzbillI agree with checking the rear of the master it is what was out of fluid and it is by the booster and if it isn't at the wheels the only other place to escape is the back of the master.
Internal master cyl leaks will make the pedal go to the floor.Joe Lutz
right here Joe
sounds like others already offered good suggestions.
Check all 4 wheels (calipers and cylinders), then pull the MC off of the booster, and look for fluid in the booster.Jim DeAngelis
My 300ZX looses all brake fluid with cold weather and no signs of leaks... after looking again i'm positive it's the seal at the back of the master cylinder is whats causing the leaks... you may have the same problem
hummm.. thanks for all the input. Ive got it in the air and the wheels are off but i cant really find an obvious leak. Of course its hard to tell cause everything is damp from winter weather driving.89SX funtop! Fully loaded!
RIP 90LX
lol... Me too.. the red one.. mysteriously low.. had to add. I am almost POSITIVE mine is going into the booster. Have had that happen on other vehicles in the past..Have had 6 Festys... and counting...
My Website:
http://www.StanfordMotorSports.com
Car Domain:
http://www.cardomain.com/id/Quaddawg
My Garage Page:
http://www.fordfestiva.com/forums/vb...o=view&id=6724
in the past year i`ve had 2 Master cylinders go bad on me in my festiva
sometimes you can pull the vac. hose loose from the brake booster and see if it is oily on the inside.if it is, it would indicate a leaking master cylinder.the leaking fluid sometimes get sucked into the engine this way.1960 willys pickup
1967 jeep cj5
1988 festiva
1989 festiva
1990 festiva for parts
1991 s-10
the booster vac hose dosent look overly oily but it isnt dry.
One thing that i really noticed is i removed the VAF (needed room to do something else) and soon as i took the air hose off i noticed this nasty smell.. cant really explain it, its not oil or gas or anything, but inside the air hose smelt terrible! and it wasn't like that before.89SX funtop! Fully loaded!
RIP 90LX
