Steering wheel removal
  • Steering wheel removal
    I have an 89 Festy on which im attempting to install a grant steering wheel. I cant seem to get the horn pad off, so before i break anything, is there a secret? I pulled the 2 screws from the outside edge of the pad, i can pull the pad away from the wheel abit bit but thats where it hangs up. It is somehow attached to a metal plate thats screwed to the main mounting plate
    Help :?
    Thanks
    89 LX 5 spd, AC, Lowered, Tint and Black Primer
    230,000+ miles.
    you can pop the center logo off to get to the main bolt
    89SX funtop! Fully loaded!
    RIP 90LX
      Pull off the Ford emblem... It's a 19mm bolt holding it on.
      You can use a steering wheel puller... I have better luck grabbing at 9 and 3, and then just pushing and pulling from one side to the other. Just watch, it'll fly off!
      Simon - pimptiva.com
        I leave the bolt screwed in a couple of turns so that doesnt happen
        96 Ford F-150 XLT
        93 Festiva L (Modified)
        92 Festiva L
        68 Mustang GT 428cj
          Thanks for the info, the wheel came off easy after that. The new problem is that the Festy spline is a smaller diameter than the wheel. Do they make an adapter for this? I purchased this wheel off of Ebay from someone who said they pulled it right off of their 93 Festy, no adapter necessary. Is there a size difference in the splines between an 89 and a 93?
          Thanks
          Jeff
          230,000+ miles.
            Yes they make a Grant adapter for your wheel , available at most parts stores .
            HD2500 Duramax Chevy
            Z28 LS1 power 500 +
              Thanks
              230,000+ miles.
