Hello all,
A problem has just reared its ugly head.
When driving up a fairly long hill the car will hesitate or miss momentarily. Same thing happens when the revs hit about 4000 under hard acceleration. The engine light doesn't come on.
I can rev it up with no load (sitting in the garage) and there is no miss that I can hear.
I've switched out the plug wires with no apparent effect. Other than this the engine runs well, revs freely and starts up just fine.
It feels more like its starving for fuel so I'm going to switch out the fuel filter tomorrow and see if that helps.
Here's a few more details
- '88 fuel injected B6 with the correct ECU and distributor with approximately 275,000km (165,000 miles)
- air filter recently cleaned (K&N)
- no vacuum leaks (checked thoroughly when I did the swap back in September)
Any ideas greatly appreciated.
Thanks
Thanks
