On one of my Festivas the shifter can be put into say first gear and moved around in a complete circle... you can't feel the "H" pattern at all! What do I need to fix this?
Shifter Loose
most likely shifter bushings. FB71 is selling them on here i believe. look in the for sale forum.89 L, hopefully returning from the dead soon with a little more power... :twisted:
http://www.fordfestiva.com/forums/sh...77-my-89-build
Can you shift into any other gear ?
The last Festiva that I had that did that had a shifter gate inside the tranny was broke .------------------------------------------------
HD2500 Duramax Chevy
Z28 LS1 power 500 +
Yep , most likely the shifter bushings then have deteriorated and now you have excess play .
Can you pull the shifter up , or is it solid in the floor .
Meaning the shifter itself can fall down thru the floor .------------------------------------------------
Z28 LS1 power 500 +
FB71, F3BZ....gaa why so many F's?! :lol:
my bad FB71.89 L, hopefully returning from the dead soon with a little more power... :twisted:
I'll check that out tomorrow. Thanks so far for the help.Originally posted by packrat427Yep , most likely the shifter bushings then have deteriorated and now you have excess play .
I have the same problem, so keep us updated on how you fix that...Denis
1993 Ford Festiva XL ~ daily driver, 173000km ~ http://www.cardomain.com/ride/2880751
1991 BMW 318is ~ project car, 178000km ~ page not made yet
Yes, your shifter bushings are definitely the problem. For the shifter base, you can replace the shot rubber bushing with washers that you can size up at the hardware store. That'll firm up the base a bit. For the cables, you'll need some replacements... you could use steel rollerblade bushings that will fit in the place of the bearing in the bearing race. It's a popular mod with Mitsubishis and Hondas. After that, you should have a firmer shift than stock
1988 Chevy Sprint Turbo 997cc
Just replace mine bushings that fix it, got it from F3BZ
here is his post
The line up -
2016 Focus RS
2005 Mini Cooper S
1995 Turbo Mustang
1986 Buick Grand National
1991 Escort GT (Daily)
1980 Fiesta
