plastic bushings definitely
Shifter Loose
replaced mine 2 days ago, worked great! thanks F3BZ!89 L, hopefully returning from the dead soon with a little more power... :twisted:
http://www.fordfestiva.com/forums/sh...77-my-89-build
On my Mazda 121 the shifter was dropped down, but you can fix that easily. I just removed the plastic holding the rubber "boot" on it (mind you, it takes a bit of time to put the boot perfectly afterwards, but that's just cosmetic) and then I simply pulled the shifter up. There is a rubber bushing that pops back in place when you pull the shifter up. If it's not too worn it will stay in place until someone sits on the shifter! :shock: (mistakenly or intentionally?)
