ok just a quick question
are the fuseable links all suposed to show 12 volts on either side of the link?
i have 3 wires the first one from lest to right is brown and getting around 4 volts on either side with the key in the run position
the second or middle one is black and labelled main and gets 12 volts on both sides with the key in the run position
the third is brown again and labelled head and gets 4 volts or less on either side.
now when i tug on them slightly they do not loosen but i havent taken them out yet to take a better look.
i ordered the expencive ignition control module and if it isnt that or this fusible link then i will be at a real loss ,
God I miss cheap drinks that are strong enough to knock you on your butt in a bar for less than $5
