93 festiva GL 2 automatic Not starting( ignition system ?)
  • #16
    i havent checked the wiring anywhere else ( dont really know how to other than wiggling while trying to crank)
    where is that fuseable link btw?
    im in daytona beach florida of all places.will add it to my profile ( not many festivas in this area )
    • #17
      Little brown box , on the drivers inner fender , has 3 wires looped on top of it .
      HD2500 Duramax Chevy
      Z28 LS1 power 500 +
      • #18
        ahh ok. what kind of things should i be trying with it. i have wiggled the wires a little and nothing but thats all i have tried on it so far.
        is it safe to un screw it and take a look while the car is off or is it hot?
        • #19
          I think it may have power on 1 plug , no bid deal.
          I took a emery board /fingernail file , trimmed it down to fit in the hole , then pulled the wires out and ran that board down in the connector , to clean it up .
          Did you check all the other connections on the VAF and disty yet.
          1 more thing , do you know if the fuel pump is running ?
          Can you try spraying something into the intake , to see if it will run at all .
          All you hoses on the intake must be connected for it to run also .
          Z28 LS1 power 500 +
          • #20
            the rest of it like the fuel pump and everything should be perfect. i mean it really runs nice.
            i took off the distributor and cleaned the inside of it which didnt really need it and it has a new cap and rotor and my wires are good leading to the plugs and coil.
            if i wanted to check the connection to it from the coil to see if the spark is coming through the coil i would just pull off the main lead and volt meter to the neg battery terminal and positive to the main lead coming off the coil while its cranking right?
            • #21
              You mean it used to run nice ??
              you have lost me now .
              That does not mean that something else failed .
              Z28 LS1 power 500 +
              • #22
                true i had that happen before the 3 jumper wires on the brown box
                • #23
                  if i'm right its on the driver strut housing
                  • #24
                    i mean it was just very apparent that it was electrical from the way it failed . driving along rpm perfectly steady no sputter or anything and then wack failure as if i pulled the key out. and then getting it restarted the first and second times by playing with the distributor .
                    • #25
                      Hey....hey....don't forget the original post..."just dropping out...What about the master relay (or what ever it's called, i don't know the acronym)
                      Remember the key....in run position...directly supplies the coils and the the relay. The relay supplies everything else.
                      Joe Lutz
                      The SKATE ..... 1992L 5spd
                      • #26
                        does it have a distrutor???? if it does the main reason u aint getting spark is because your points in other words a black box in side the distributor is bad that why u are not getting any spark let me pull of picture of wut i mean
                        Ignition Module/Control Unit
                        Ignition Pickup/Stator
                        • #27
                          both together run u about $170.00 or just get a replacement one a replacment one would be the way cardone reman cost $177 with $30.00 core www.partsamerica.com
                          • #28
                            but i have spark going into the wire right before the coil which is after the control unit correct ? it cost about 100 at autozone. and for that sator i dont have one in the distributor . i took it completely apart and its got a CPS under the rotor
                            • #29
                              little black box right
                              then its a 91 distributor someone must of replaced it before u did
                              • #30
                                Ignition Module/Control Unit this is wut give and supplies juice this sounds likr the same problem i was having with my 88 power for a n hour or 2 naby less then boom no spark then spark so yeah thats your problem heres wut it looks like
