brake reservoir question.
  • brake reservoir question.
    What tool or tools have you used to reinstall the brake reservoir on a new master cylinder? Destroyed one on the first attempt at 22 degrees. Lubed it up good and it started in ok but trying to get it fully seated is what did it in. Is there a trick for doing this? Thanks
    Is that someone there ??? 1981 VW diesel pickup---1988.5 Suzuki Samurai tin top---1993 Festiva---1974 Bricklin SV-1 ( very thirsty basket case)---2003 Tracker(bells and whistles)
    I would try to do it where it is warm .
    Cold weather like that does not work well with seals giving , when putting them together .
    The lube should help , just bring it inside and let it warm up first .
    HD2500 Duramax Chevy
    Z28 LS1 power 500 +
      ^^ x2 , just don't try to speed up the process!
        make sure to use brake fluid as the lube....plenty of it...and nothing else.
        Joe Lutz
        The SKATE ..... 1992L 5spd
          Well i got another reservoir and had everything warm and lubed with brake fluid. It was still a no go.
          It would enter the seals but it would not pop fully down into place. So i put it aside untill the summer heat arrives. Got on the phone and called the local yards and found a used factory one for ten bucks. Pulled it off,checked it for leaks,pumped it with a screw driver and it shot out about two feet. Bench bled it,put it on and i'm back in biz! The new one i got from Auto Zone is a different style casting. And i,m thinking it might be for something else. At fourty bucks with a twenty dollar core i will be inquiring! Thanks guys
            They have new ones on Rockauto.com with the reservoir for $57
            1986 Comp Prep SVO Mustang(1 of 83) Four cylinder turbo! (Think first Fox body "R" model!)
            1969 Ford F100 Big Block Ranger and it was free! (coming 2/12)
              Different casing means some punk might opf ordered the wrong one, way 2 go!
                at the junkyard one time a saw a wierd looking master cylinder on a festiva like there was two styles
