Can anyone tell me where the headlight relay is located on a '92 Festiva? Neither the shop manual or Haynes are very helpful with this.
I'm assuming the relay is my problem. I have no headlightsat all... no high beam, low beam or daytime running lights. I've checked the main headlight fusible and its OK and all the other lights work as they should. I am going to check the bulbs themselves but I would be very surprised if they completely burnt out at the same time.
Thanks
Ian
92 GL Sport
Calgary
Thanks
Ian
92 GL Sport
Calgary
It's on the right hand side below the battery and the parking light relay is the one behind the airbox on the left.
