Hello
I've been looking in the forums for a way to retrieve the error codes of a ford festiva. ('88 LX, 1.3 Carb)
I just took the 1 pin test connector and connected it to the chassis. Here's what I did:
Simple ground cable
When I was about to connect an analog voltimeter I saw that the check engine light started blinking when I put the key in "on" position.
I'm not sure how to read the results... it's supposed that slow blinks are for the first digit and fast ones for the second... I don't know If I have more than one code, can somebody check the video and help me?
Here's the video
I believe the codes are: (Not sure, don't know if the codes I found are for a Festiva)
9 ECT Sensor
18 Ignition TACH signal erratic - Ignition Systems
19 No Vehicle Power (pins 37 + 57) or bad PCM VPWR Diagnosis
20
21 Engine Coolant Temperature (ECT) sensor out of range - ECT
22 MAP (vacuum) or BARO signal out of range - MAP
28 Vane Air Temperature (VAT) sensor out of range - VAT
70 Data link to instrument cluster fault Service any other EEC codes, erase memory and retest If code is still present refer to instrument cluster diagnosis manual
Thanks!
Simple ground cable
Here's the video
9 ECT Sensor
20
Thanks!
